Paolo Bevilacqua Thu, 01/29/2009 - 12:26
I don't think there is a requirement. CM doesn't really know what exact kind of card it is.
shane.orr Thu, 01/29/2009 - 12:39
Actually with MGCP Controlled Endpoints on a gateway it does have to be supported specifically in Call Manager usually but the good news is I just referenced a CM 6.1(2) and the VIC3-4FXS/DID is in the list.
thomuff Wed, 05/06/2009 - 08:32
Do you have a list or did you just look at the Call Manager. I am trying to figure out if a VIC3-2FXS/DID is supported in Call manager 4.2(3)SR3? Thanks in advance
shane.orr Thu, 05/07/2009 - 05:56
No unfortunately I never was never able to find a compatibility matrix. I just saw it under the particular CM Version that I was working on at the time.
thomuff Thu, 05/07/2009 - 07:20
I have a TAC case opened. They are researching the version.
shane.orr Thu, 06/04/2009 - 06:34
Just wanted to follow up on this, did you ever get a good compatibility matrix or anything for hardware to call manager software or any other good resource for this?
pgcristovam Wed, 09/09/2009 - 08:17
Hi Thomuff.
The TAC says to you what version support the VIC3-4FXS? My CCM is 4.1.x
Peterson
etmarcof Wed, 09/09/2009 - 14:44
I'm having working VIC3-4FXS with MGCP (IOS 12.4.24T1) and CCM 7.0.2b
MC
