NAT inside with diferent IP that overload
Jan 29th, 2009
Hi all,
I have a mail server that I need it to have access from the outside (that is done), but I also need it to get out with that same address (different from the interface overload address) and here is the problem. I have to use the static with a route map so I can access the mail server from my other location using the VPN (other wise it will be nated and unreachable).
I have this:
ip nat inside source static 192.168.60.250 210.xxx.xxx.xxx route-map NAT_179
ip access-list extended NAT_179
deny ip 192.168.60.0 0.0.0.255 192.168.60.0 0.0.0.255
deny ip 192.168.60.0 0.0.0.255 192.168.1.0 0.0.0.255
deny ip 192.168.60.0 0.0.0.255 192.168.2.0 0.0.0.255
deny ip 192.168.60.0 0.0.0.255 192.168.20.0 0.0.0.255
deny ip 192.168.60.0 0.0.0.255 192.168.30.0 0.0.0.255
deny ip 192.168.1.0 0.0.0.255 192.168.60.0 0.0.0.255
deny ip 192.168.2.0 0.0.0.255 192.168.60.0 0.0.0.255
deny ip 192.168.20.0 0.0.0.255 192.168.60.0 0.0.0.255
deny ip 192.168.30.0 0.0.0.255 192.168.60.0 0.0.0.255
deny ip 192.168.10.0 0.0.0.255 192.168.60.0 0.0.0.255
deny ip 192.168.60.0 0.0.0.255 192.168.10.0 0.0.0.255
permit ip any any
Any idea on how I can do this?
Edit: problem solved, just a matter of ACL
