Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1926974members
1239358discussions
Community Activity
End point detection
I am new to cisco endpoint and will need some help in creating rolling 3 months analysis for end point positive detectionsand also analysis for false positive detection.Any help and directions will be deeply appriciated.Thanks
neroblaze by Level 1
  • 62 Views
  • 2 replies
Internal batteries
Does the Catalyst 2960-X or 350-P network switches have internal coin cell batteries to retain memory or clock settings? If so, what is the part number of this battery. Alternatively do you have a safety compliance document for the battery which allo...
フラグメント後に拒否されるはずの最初のパケットが拒否されない
2024年3月1日 (初版) TAC SR Collection主な問題 フラグメントされたパケットを IP アドレスのみを指定し fragments キーワードを設定した access-list で deny しようとすると、最初のパケットのみ拒否されません。 原因 上記は実装動作です。詳細については下記ドキュメントにて記載されます。L3 情報だけで ACL 行が拒否され、fragments キーワードが存在する場合、パケットの L3 情報が ACL 行の L3 情報と一致すると、パケットのフ...
Upcoming Event: Capture the Flag, get the Badge!
You asked, we heard you! Introducing the ThousandEyes Support Community Capture the Flag event from April 23rd at 8 AM PST to April 29th at 5 PM PST. This month the ThousandEyes Community is offering two Capture the Flag missions in a single upcoming...
Error en AP
Buenas tardes.Tengo un AP modelo AIR-CAP3702I-N-K9, el cual funciona bien por algunos días, pero de repente deja de enviar la señal de interfaz de red Radio1-802.11AC5GHz deja de aparecer visible la red configurada como 5Ghz y por tal motivo no puedo...
Miriam T by Level 1
  • 20 Views
  • 0 replies
HSRP Not Establishing but L2 Connectivity Verified
Replacing some old cisco routers with 8500's running 17.9.4a.  They are connected to a Nexus 7K, on the same card.  The routers can ping one another and establish BGP but they will not establish the HSRP adjacently across the 7K.  If the 8500's are c...
ATX録画と資料:Cisco Data Center Compute ソリューションの概要
本 Ask the Experts では、Cisco Data Center Compute のソリューション、関連製品、およびユースケースを紹介します。さまざまな機能の紹介、コストやエラーの削減といった技術的成果およびビジネス成果について説明します。Cisco のテクノロジーがお客様の組織にもたらすメリットや、求められる成果を実現する方法を理解できます。(英語タイトル:Cisco Data Center Compute Solutions Overview)     Ask the Expe...
Unable to ping between two tunnel points
Hello, I built using the packet tracer a simple topology of three routers with ospf routing. I created a tunnel between the two routers that are not physically connected to each other, but I can't ping between one end and the other. I managed to ping...
Script for Switches Cisco
Hello Community,I am looking a script for switches cisco for block interfaces with APs connected , the reason is because we receive daily port changes and sometimes the engineers change the vlan Wi-Fi by another and the Wi-Fi environment is affected ...
Cisco ISE2.7 バックアップの復元について
GUIでのバックアップの復元方法について探しております。公式サイトでは管理者ポータルのバックアップと復元からrestore(復元)を選択と記載がありますが、肝心のrestore(復元)ボタンが見当たりませんのでご教示いただけますと幸いです。
nn112233 by Level 1
  • 47 Views
  • 0 replies
