Routing two addresses to remote over tunnel and other address go public
Answered Question
Jan 29th, 2009
I have two IP addresses that need to communicate to a remote external IP addresse over established lan to lan tunnel vpn tunnel. All other local machines would route to remote external Ip address over public connections. What is best way to accomplish? Thanks
Correct Answer by John Blakley about 8 years 5 months ago
Tom,
I'm glad to hear it worked, and thank you for the rating. =)
John
Overall Rating: 4.5 (2 ratings)
John Blakley Thu, 01/29/2009 - 14:53
  • Purple, 4500 points or more
I would say a policy map would be the best way to go in this situation.
route-map TUNNEL permit 5
match ip address TWO-HOSTS
set ip next-hop
access-lists TWO-HOSTS
permit ip host 192.168.1.1 host 172.17.2.2
permit ip host 192.168.1.2 host 172.17.2.2
int fa4 (public address where crypto map is)
ip policy route-map TUNNEL
I don't know if this will work, but it could be a good start
HTH,
John
thomuff Fri, 01/30/2009 - 09:38
Here is follow-up question:
What happens when 192.168.1.3 tries to connect to 172.17.2.2
Is it discarded or routed normally?
Lan segment is 192.168.1.0/24
192.168.1.1 is local router DG and ip address on int fa4
Firewall is 192.168.1.250
ip route 0.0.0.0 0.0.0.0 192.168.1.250
VPN Concentrator is 192.168.1.100
What would happen to traffic that doesn't match policy route map, would it discard or route normal.
thomuff Fri, 02/06/2009 - 06:49
John,
Can you reply to this post one more time? Your post resolved my issue and I would like to give you credit.
Tom
Correct Answer
John Blakley Fri, 02/06/2009 - 07:45
Tom,
John
