IP SLA HTTP Monitor - Sending trap on timeout
Jan 29th, 2009
I'm trying to get a notification sent via SNMP trap when a IP SLA HTTP Monitor has a connection problem.
<br />
<br />Is the the correct IOS configuration?
<br />
<br />ip sla monitor logging traps
<br />
<br />ip sla monitor 500
<br /> type http operation get url http://www.cisco.com source-ipaddr 10.7.1.12
<br /> timeout 10000
<br />
<br />ip sla monitor reaction-configuration 500 react connectionLoss action-type trapOnly
<br />
<br />ip sla monitor schedule 500 life forever start-time now
pgasparovic Thu, 02/05/2009 - 03:26
HI man,
im studying all that stuff for some project, and I'm quite sure that ConnectionLoss is what the name truly suggests - a failure of established connection. Unfortunately I didnot perform any CLI test for c.l. to support my response.. So set the trap on timeout violation.
Anyway, I miss there SNMP server config.. (did you really forget to apply?). Refer to 12.4 IOS IP SLA guide, it's there. Regards.
