NAT on VPN IP Pool
Answered Question
Jan 29th, 2009
Would just like to ask if it's possible to NAT the ip pool of VPN remote-access users to the router's outside IP address? The router is a Cisco1841.
Thanks!
Correct Answer by JORGE RODRIGUEZ about 8 years 6 months ago
Patricia,
Are you refering to PATing your RA IP pool using your outside interface just as you do with your LAN subnets in ip nat overload?, if so this link depicts similar example using route map, PLS let us know if this is not what you are looking for and if you could perhaps elaborate as to what is it that you are trying to accomplish.
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_configuration_example09186a008073b06b.shtml
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Thu, 01/29/2009 - 21:25
  • Green, 3000 points or more
Patricia,
patricia20 Sun, 02/01/2009 - 12:26
Your understanding to my problem is right.  I'll try to test the sample config from the link you've posted.  The main issue is that we wanted to access a group of servers outside our network while connected to the VPN.  Unfortunately, putting up an L2L VPN in between is out of the question.  We need to translate the RA IP pool to the outside interface as this IP address has access to the remote servers.  If you have links that would best describe this problem, that would be wonderful.
Patricia
