DFM import devices hang in "Learning" state - 10% completed
Jan 29th, 2009
Hi all,
I have done the Device Import in DFM. But the status discovery is 10% completed. It has been a week now. I have no idea what to do.
Any idea? Thank you.
Joe Clarke Thu, 01/29/2009 - 20:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post the output of the pdshow command. What version of DFM is this? On what platform?
nizammuddin Mon, 02/02/2009 - 02:03
Hi Joe,
The DFM version is 3.0.2.
The platform is Windows 2003 server Standard Edition SP2
Any solution? Or do you need more info?
Thank you.
Joe Clarke Mon, 02/02/2009 - 09:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Upgrade to DFM 3.0.4, and this problem will go away. It should also fix the problem where some of your daemons are crashing (e.g. TomcatMonitor). You can get DFM 3.0.4 under Common Services > Software Center > Software Update.
nizammuddin Wed, 02/04/2009 - 18:31
I have updated DFM 3.0.4. All device has been learned in DFM. All devices in "Known" state.
All processes is also UP except for 2 process is down which is DFMCTMStartup and DataPurge.
Thank you Joe
Joe Clarke Wed, 02/04/2009 - 22:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
These two processes may be down in normal operation. It does not indicate a problem.
