Requirement for converting from Autonomous to LWAPP in future.
Jan 29th, 2009
Currently one of my customers is running Autonomous IOS version 12.3(7)JA.
He wants WEP and WPA support and in future wants to able to be convert from Autonomous to LWAPP.
According to the following link version 12.3(7)JA should allow him to go to LWAPP - right?
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072d9a1.shtml#Operation
Second question:
12.3(8)JA2 in the JA train is higher maintenance release - right.
What do the releases with JEB and JEC i.e the second letter "E" after the J. refer to? The last letter refers to a sequential release number/letters. A, B, C .. and so on.
What new features are available with JEB, JEC etc. ?
Overall Rating: 5 (1 ratings)
Rob Huffman Fri, 01/30/2009 - 11:24
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Alphonse,
Question#1 - Yes,12.3(7)JA will set you up for the LWAPP upgrade process :)
Question#2 -
This is actually a fairly complicated question. If you look through the release notes you will see that what we have here are different IOS Releases for Maintenance Fixes,New Features, LWAPP Recovery/Upgrade Images, ***different IOS's for 32Mb and 16Mb 1100 series platforms etc. etc :(
That being said, upgrades that flow along the same train like 12.3.8-JEA to 12.3.8-JEA2 will be safe and supported.
Here is the 1200 Series IOS Release Page and some examples of the different IOS Releases that I was trying to highlight above;
http://www.cisco.com/en/US/products/hw/wireless/ps4570/prod_release_notes_list.html
12.3(11)JX - **stay away from the "x" versions until using LWAPP.
Cisco IOS Release 12.3(11)JX provides support for the lightweight access point protocol (LWAPP) for 1100, 1130, 1200, 1230, 1240, and 1300 series access points. When you use the Autonomous to Lightweight Mode upgrade tool to upgrade one of these access points to this release, the access point communicates with a Cisco wireless LAN controller and receives a full LWAPP configuration and software image from the controller. This release also functions as a recovery image if the access point fails to receive a full image from the controller.
12.3(8)JA2 - Check Resolved Caveats
http://www.cisco.com/en/US/docs/wireless/access_point/ios/release/notes/b38ja2.html
12.3(8)JEB1
Cisco IOS Release 12.3(8)JEB1 is a general maintenance release that concentrates on bug fixes and includes minor features. You can install Cisco IOS Release 12.3(8)JEB1 on any Cisco Aironet access 1100, 1210, or 1230 series access point.
12.3(11)JA1
Cisco IOS Release 12.3(11)JA1 supports autonomous 32 Mb platforms. 16 Mb platforms and platforms supported by Cisco IOS Release 12.3(8)JA and earlier (350, 1100, 1130, 1200, and 1230 series access points and 1300 series access point/bridge) are supported by Cisco IOS Release 12.3(8)JEA1.
Hope this helps!
Rob
