How to check a switch can support number of LAN
jitendra.kansal
Hi..
I am using 2940 swithc (8-Port). My question is -
by which command/procedure, i can check a swich will support how many vlans?
10 Replies 10
Tshi M
Level 5
Level 5
The command might sh vtp stat
sh vtp stat
VTP Version : 2
Configuration Revision : 29
Maximum VLANs supported locally : 1005
Number of existing VLANs : 15
VTP Operating Mode : Server
VTP Domain Name : S-HB1
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Enabled
MD5 digest : 0xF9 0xAD 0x14 0x07 0xB4 0x8B 0x82 0x93
Configuration last modified by 10.x.x.x at 3-1-93 04:31:21
Local updater ID is 10.x.x.x on interface Vl1 (lowest numbered VLAN interface found)
glen.grant
You shouldn't need too many with only 8 ports . Early versions of the 2940 did not support many. Newer versions of IOS supported more.
True. I guess I was just referring to how to find out the max vlan supported.
Hi Glen,
Thanks for your valulable support. show version output is attached herewith. Please be advise with the newer IOS.
Thanks in Advance---Jeet
------------------ show version ------------------
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(25)SEE3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 22-Feb-07 15:04 by myl
Image text-base: 0x00003000, data-base: 0x00EE40E0
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
GSI_Rajaji_CHE uptime is 4 hours, 41 minutes
System image file is "flash:c3750-ipbase-mz.122-25.SEE3/c3750-ipbase-mz.122-25.SEE3.bin"
cisco WS-C3750-48TS (PowerPC405) processor (revision N0) with 118784K/12280K bytes of memory.
Processor board ID CAT1115NJAJ
Last reset from power-on
3 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1B:90:65:1C:00
Motherboard assembly number : 73-9680-10
Power supply part number : 341-0028-02
Motherboard serial number : CAT1115565N
Power supply serial number : LIT110306DZ
Model revision number : N0
Motherboard revision number : B0
Model number : WS-C3750-48TS-S
System serial number : CAT1115NJAJ
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : CAT11115WPG
Top Assembly Part Number : 800-25854-02
Top Assembly Revision Number : F0
Version ID : V05
CLEI Code Number : CNMV300CRE
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 52 WS-C3750-48TS 12.2(25)SEE3 C3750-IPBASE-M
Configuration register is 0xF
Hi Glen...Waiting for your update!!!
A 3750 switch will support up to 1005 VLANs as shown by sh vlan br and sh vtp status. Both output show the max VLANs supported locally.
Hi..but i am using 2940 switch..is it applicable on 2940 also?
Jeet!!!
My bad...you posted a sh ver of a 3750. I don't have access to the 2940 but I am sure you can use the same command.
sh vlan br
sh vtp stat
regards,
oops...my mistake..plesae find correct one---
sh ver
IOS (tm) C2940 Software (C2940-I6Q4L2-M), Version 12.1(19)EA1c, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 02-Feb-04 22:53 by yenanh
Image text-base: 0x80010000, data-base: 0x80594000
ROM: Bootstrap program is C2950 boot loader
2940 uptime is 18 minutes
System image file is "flash:/c2940-i6q4l2-mz.121-19.EA1c/c2940-i6q4l2-mz.121-19.EA1c.bin"
cisco WS-C2940-8TF-S (RC32300) processor (revision C0) with 20776K bytes of memory.
Processor board ID FHK0817Y0J9
Last reset from system-reset
Running Standard Image
9 FastEthernet/IEEE 802.3 interface(s)
1 Gigabit Ethernet/IEEE 802.3 interface(s)
--More-- 32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0F:90:28:A1:80
Motherboard assembly number: 73-8783-05
Power supply part number: 341-0085-01
Motherboard serial number: FOC08151XX6
Power supply serial number: HIC080600PF
Model revision number: C0
Motherboard revision number: A0
Model number: WS-C2940-8TF-S
System serial number: FHK0817Y0J9
sh vtp sta
VTP Version : 2
Configuration Revision : 0
Maximum VLANs supported locally : 8
Number of existing VLANs : 7
VTP Operating Mode : Transparent
VTP Domain Name : GSI_NAGPUR
VTP Traps Generation : Disabled
MD5 digest : 0x70 0xBF 0x4C 0x6B 0x71 0x04 0xE7 0x58
Configuration last modified by 10.4.8.136 at 3-1-93 00:32:53
PLEASE HELP ME !!!! JEET
Maximum VLANs supported locally : 8 <<< --- Max number of VLAN supported by appliance (8)
