how to see which one is master in gigabit autonegotation ?
Jan 30th, 2009
  • Bronze, 100 points or more
On a WS-CBS3120X-S blade switch, ports are 1000 speed full duplex fixed. The only thing i can change on the port is autonegitiotion:
GigabitEthernet1/0/1
Model: WS-CBS3120X-S
Type: 1000BaseX
Speed: 1000
Duplex: full
If we have performance problems on such a port, how can i see which side has become master/slave in gigabit autonegotiotion ?
regards,
Geert
amritpatek Thu, 02/05/2009 - 07:56
  • Silver, 250 points or more
To set various operational parameters associated with the Gigabit Ethernet interface, such as the size of the maximum transfer unit (MTU) or the use of VLANs, use the interface ge? command. To disable the use of VLANs, use the no form of this command. To specify that auto negotiation will never be used on this interface, use theinterface ge? no autonegotiation command.
interface ge? {autonegotiation [autodetect] | mtusize {nn | default}
interface ge? vlan enable
no interface ge? vlan enable
The following is the show scsirouter all failover command. This command displays both configured and current operational failover information for all the SCSI routing instances in the cluster.
