CUCM 6.1(2) to 6.1(3) upgrade advice
Answered Question
Jan 30th, 2009
Hi All
I want to upgrade my cucm 6.1(2) to 6.1(3) i have downloaded two very large files with .iso_part1of2 extensions. Do i need to remove the extension from the file and leave just .iso ?
i looked for support documentation but cant find anything useful other than telling me to create a ISO DVD for the uprade which failed when i tried (im using Nero)
any help appreciated
regards
Colin
Correct Answer by Rob Huffman about 8 years 1 month ago
Hi Colin,
At the end of the day, I believe the file should look like this;
UCSInstall_UCOS_6.1.3.1000-16.sgn.iso
Upgrading From Cisco Unified Communications Manager Release 6.1(1x) or higher to Release 6.1(3) by Using the UCSInstall File
Because of its size, the UCSInstall iso file, UCOS_6.1.3.1000-16.sgn.iso, comprises two parts:
•UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part1of2
•UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part2of2
Procedure
Step 1From www.cisco.com, download the two UCSInstall files.
Step 2Execute one of the following commands to reunite the two parts of the file.
NoteThe 6.1.3.1000-16 build represents a non-bootable ISO that is only useful for upgrades. You cannot use it for new installations.
a.If you have a Unix/Linux system, cut and paste the following command from this document into the CLI to combine the two parts:
cat UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part1of2 UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part2of2 > UCSInstall_UCOS_6.1.3.1000-16.sgn.iso
b.If you have a Windows system, cut and paste the following command from this document into the command prompt (cmd.exe) to combine the two parts:
COPY /B UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part1of2+UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part2of2 UCSInstall_UCOS_6.1.3.1000-16.sgn.iso
Step 3Use an md5sum utility to verify that the MD5 sum of the final file is correct.
417c262e5706103c4e75a825e1d5d902 UCSInstall_UCOS_6.1.3.1000-16.sgn.iso
From these Release Notes;
http://www.cisco.com/web/software/282074295/24094/ciscocm-6-1-3.Readme.pdf
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Fri, 01/30/2009 - 05:30
Hi Colin,
Procedure
Hope this helps!
Rob
Rob Huffman Sat, 01/31/2009 - 08:06
Hi Colin,
Hahaha......thanks buddy! Glad to be of some help here.
Cheers!
Rob
Johann Aicher Wed, 02/04/2009 - 09:31
Hi Colin,
be aware that CUCM 6.1(3) is not upgradable to CUCM 7.0 at this time.
Reg.
Johann
