Tacaacs on WLC4404
Jan 30th, 2009
We are setting up Tacaacs to a WLC 4404 , but we are getting the following message on the WLC when we try and go through the management IP using tacaacs. Anyone seen this b4.
Jan 29 13:23:28.012 ews_auth.c:2107 EMWEB-1-LOGIN_FAILED: Login failed. User:''. Service-Type is not present or it doesn't allow READ/WRITE permission..
sschmidt Fri, 01/30/2009 - 07:30
What is the version of ACS?
What is the version of WLC code?
Scott Fella Fri, 01/30/2009 - 07:31
Daren,
One thing I know is that you can't have TACACS setup if you have Radius setup for the wireless clients. You would need a seperate TACACS server or use Radius to authenticate management access.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
