AnyConnect Installation Page Redirect - Please help
Jan 30th, 2009
I use vpn web login and install the AnyConnect Client, after check Active-X, JAVA... then finally the AnyConnect client installed and the "Connection Established". My question is, at the end there is a page notify user "vpn tunnel already Connected", does this page can be automatically redirect to another web site (or web page)? Or does this page can be customized?
Please see attached file
Many thanks
DialerString_2 Fri, 01/30/2009 - 09:28
  • Bronze, 100 points or more
I don't know about that page, but there are customization that can be performed on the asa. I actually just finished customizing ours. And yes you can redirect that to another page - I can't remember off hand how to do it.
rico_hao40 Mon, 02/02/2009 - 13:08
Thanks.
Yes, I found the way to customzie the portal login page which I believe is the one you customized. But I also want the solution edit that page showing in my attached file.
DialerString_2 Mon, 02/02/2009 - 13:44
Try this. Open ASDM > Configurations > Remote Access VPN > Portal - Customization.
Select your template, clik edit.
Select portal and then Home Page.
You should be able to redirect here if I'm not mistaken. I hope this works for you.
