Tshi M Fri, 01/30/2009 - 08:16
  • Silver, 250 points or more
could you please post the exact message and also the command used to delete the bin file?
regards,
glen.grant Fri, 01/30/2009 - 08:22
  • Purple, 4500 points or more
Is it a .bin file or is it a directory with the .bin file inside ? If you do a "dir flash" how many images are in flash?
6tgreene Fri, 01/30/2009 - 08:45
Now that you point that out it is a dir. I changed to the dir and was able to delete the old file. I just completed the the new code upgrade. Thanks for the thought problem solved.
glen.grant Fri, 01/30/2009 - 08:53
To delete the directory , "delete /force /recursive flash:
