tcp connection being disconnected vpn
Jan 30th, 2009
  • Bronze, 100 points or more
Ok - I have 2 end user that connect via vpn and once connected they 23 to a unix box. After being idle for 1 hour or so, that telnet connection will drop, however the vpn connection remains up.
<br /><br />
<br /><br />Any help will do!!! I'm thinking about setting the timeout conn to a hire value.
<br /><br />
<br /><br />timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
<br /><br />
RicheeJJJ_2 Sun, 02/01/2009 - 12:44
This sounds like a problem on the Unix machine and not the cisco device.
Check the timeout settings on the unix box for telnet timeouts.
