CUCM hardware & license
htarra Thu, 02/05/2009 - 06:48
  • Bronze, 100 points or more
LIC-CM7.0-7816= License CM 7.0 7815/7816 Appliance, 500 seats $3,995
P.S: you need to check the hardware compatibility of
the server using the matrix and see if the UCS 7.0 is
supported by the customer MCS.
mwibowo Tue, 04/28/2009 - 20:50
Hello, so are you saying that the LIC-CM7.0-7816= can be installed on the MCS7825H3-K9-CMC1? I mean the CM7 license does not necessarily match to the MCS server model? For example: LIC-CM7.0-7816= does not necessarily require MCS7816H3-K9-CMC1 because it can be installed on MCS7825H3-K9-CMC1, is it?
