tests and sim questions
Jan 30th, 2009
In the sim questions on the exams, do you have to save the config to get credit for the question?
scottmac Fri, 01/30/2009 - 11:34
Well, they apparently don't deduct for it, and it's only one command .... go for it; it's a good practice, get used to doing it.
Good Luck
jrensink78 Sun, 02/01/2009 - 08:24
I have never heard a definitive answer on this.  Unless the question asks you to save the conifguration, you shouldn't need to.  The question is graded when you click next, so it's not like it gets loaded up anywhere.
But, it does only take a few seconds to do, and it won't hurt anything.  I always did, just because I was paranoid about it.
