how to isolate debug of vpn on ASA
Jan 30th, 2009
I've got an ASA that has over 50 IPSEC tunnels on it. It's running versiion 7.24 code. Is there a way I can turn on debugging and just look at messages as it pertains to one particular tunnel? I'd like to be able to troubleshoot a particular vpn if it does not come up, and debug isakmp and ipsec on it. I don't want to debug globally out of fear I might crash it, and also its a pain to have to filter through all the other active tunnels that I am not looking to see.
Ivan Martinon Fri, 01/30/2009 - 13:57
  • Cisco Employee,
Unfortunately ASA 7.2 has no option to condition the ipsec debugging as ASA 8.0 does, but you can send your debugs to a syslog and search or sort these by the ip address affected, you can do this with the command "loggin debug-trace" this will start sending the debugs to your syslog configured.
pstebner10 Fri, 01/30/2009 - 14:10
You can set filters on your debugging, so that you only see messages from one particular tunnel:
debug crypto condition group
or by peer address:
debug crypto condition peer www.xxx.yyy.zzz
and then enable dubugging.
HTH,
Paul
pstebner10 Fri, 01/30/2009 - 14:11
sorry - that works on 8.x code - i didn't realize it didn't on 7.x
paul
