Local Access to home network
Jan 30th, 2009
I am using the Cisco VPN Client version 5.0.01.0600. I can connect to the VPN resources fine. However, as soon as I log into the VPN network I lose all connectivity to my local physical lan. My machine is dual homed and one of the IP addresses shows the local lan and the other shows the VPN lan. Is there any way to access both lan segments at the same time?
JORGE RODRIGUEZ Fri, 01/30/2009 - 21:04
  • Green, 3000 points or more
John,  yes it is possible , it is called split tunnel ..   the far end VPN gateway will have to allow that by configuring the  RA tunnel as a  (split tunnel).
schrader_john Sat, 01/31/2009 - 18:09
Thanks for your help, I'll contact the admin for the other end.
