LWAPP: QOS
Jan 30th, 2009
What is cisco best practice for a LWAPP port on an edge switch. WLAN is using 7921 handsets.
Should I use STP portfast ?
What QOS marking on the access port.
### current ####
int fa0/1
switchport
switchport mode access
switchport access vlan 10
mls qos trust dspc
Stephen Rodriguez Fri, 01/30/2009 - 10:43
  • Purple, 4500 points or more
current setup is fine, recommended is to trust DSCP. As for spanning-tree configs, that's up to you. Spanning-tree portfast should be fine, could possibly use bpduguard enable if it's part of your normal edge security policy.
HTH,
Steve
Stephen Rodriguez Fri, 01/30/2009 - 10:44
HTH,
Steve
ericgarnel Fri, 01/30/2009 - 12:10
  • Gold, 750 points or more
Here is a helpful guide:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a0080810880.shtml
Yes, use portfast on ap switchports, they are considered hosts.
You could also use the built in macro "switch host" (sw ho) which puts the port in access mode & porfast - a great combination with the interface range command.
I believe the dscp is correct (instead of cos)
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
