01-30-2009 10:35 AM - edited 03-04-2019 01:03 AM
Hi i am on ASA and want to SSH my neighbour router, is that possible?
01-30-2009 10:55 AM
I am afraid that you can't. I think this has to do with security.
01-30-2009 11:23 AM
You can as long as your router has a crypto image (k9 in th IOS name) and you create crypto keys.
#crypto key generate rsa general-keys modulus 1024
01-30-2009 11:29 AM
I think the post was asking to ssh from the ASA to another device inside the network.
12-16-2018 03:39 PM
Crypto key generate every time! ; )
Try it.
12-17-2018 06:59 AM
No matter how many crypto keys you generate the ASA still does not support being a client for telnet or for SSH. The issue in the original post is not about crypto keys (which are not an issue for telnet) but is about the security architecture of the ASA.
Rick
01-31-2009 12:01 PM
No can do. You can NOT SSH/Telnet from an ASA.
02-02-2009 04:38 AM
i also came to this conclusion, after searching alot on net, thank you all for your input,
