TACACS+
Jan 30th, 2009
Loging into a Cisco switch I want the below options to work. Im using Cisco ACS v4.1 and a cisco 3560 switch.
Is this possible
Switch login options:
1. TACACS+ server authenciation (Cisco ACS) ---
2a. TACACS+ server fails (Cisco ACS) - use local switch AAA username & Password
2b. TACACS+ username and password incorrect (Failed login on ACS) - use local switch AAA username & Password
! Console port
3 Console port use local AAA username and password only
Overall Rating: 3 (1 ratings)
Collin Clark Fri, 01/30/2009 - 11:46
  • Purple, 4500 points or more
1. aaa authentication login VTYMethod group tacacs+
line vty 0 4
login authentication VTYMethod
1a. aaa authentication login VTYMethod group tacacs+ local
line vty 0 4
2b. AFAIK you can't do that
3. aaa authentication login CONSOLEMethod group local
line con 0
login authentication CONSOLEMethod
Hope that helps.
Daniel Laden Sun, 02/01/2009 - 12:55
  • Cisco Employee,
2b. You will not be able to do this.  The local method is only checked if the TACACS method is unresponsive.  A failed TACACS authentication is an active response.
