QOS with GRE tunnel
Jan 30th, 2009
  • Silver, 250 points or more
Got a remote site linked to my main campus by a encrypted GRE tunnel. The remote site gateway is also SRST. My problem is the remote site gateway is losing it's connection from time to time with the campus CUCM.
I was able to give priority to the phone over the wan link with QOS pre classify. For the MGCP, I've got no match.
Any idea?
Edison Ortiz Fri, 01/30/2009 - 19:32
  • Hall of Fame,
    Founding Member
MGCP uses TCP/UDP Port 2427
Can you post config and service policy output?
__
Edison.
dominic.caron Mon, 02/02/2009 - 08:10
GigabitEthernet0/1
Service-policy output: parent_shaping
Class-map: class-default (match-any)
1431901218 packets, 1160148436053 bytes
5 minute offered rate 10000 bps, drop rate 0 bps
Match: any
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
1544000/1544000 9650 38600 38600 25 4825
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 0 1428775733 2206489236 801325183 2505788639 no
Service-policy : child-shaping-GigabitEthernet0/1
Class-map: Voice-GigabitEthernet0/1 (match-any)
124630577 packets, 29388460155 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: protocol rtp audio
0 packets, 0 bytes
5 minute rate 0 bps
Match: ip precedence 5
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 72
Bandwidth 70 (%)
Bandwidth 1080 (kbps) Burst 27000 (Bytes)
(pkts matched/bytes matched) 41102498/12680153548
(total drops/bytes drops) 0/0
QoS Set
dscp ef
Packets marked 124630577
Class-map: Trans-GigabitEthernet0/1 (match-any)
11743 packets, 2173208 bytes
5 minute offered rate 1000 bps, drop rate 0 bps
Match: protocol ssh
11729 packets, 2172408 bytes
5 minute rate 1000 bps
Match: protocol telnet
14 packets, 800 bytes
5 minute rate 0 bps
Queueing
Output Queue: Conversation 74
Bandwidth remaining 33 (%) Max Threshold 64 (packets)
(pkts matched/bytes matched) 4752/766900
(depth/total drops/no-buffer drops) 0/0/0
QoS Set
dscp af21
Packets marked 11751
Class-map: Signal-GigabitEthernet0/1 (match-any)
0 packets, 0 bytes
Match: protocol mgcp
0 packets, 0 bytes
5 minute rate 0 bps
Match: ip precedence 3
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Output Queue: Conversation 76
Bandwidth remaining 40 (%) Max Threshold 64 (packets)
(pkts matched/bytes matched) 0/0
QoS Set
dscp cs3
Packets marked 0
1307258961 packets, 1130757871642 bytes
Match: any
Queueing
Output Queue: Conversation 77
Bandwidth remaining 20 (%) Max Threshold 64 (packets)
(pkts matched/bytes matched) 762794224/778641892439
(depth/total drops/no-buffer drops) 0/3125545/0
Vlan820
Service-policy input: voice
Class-map: voip (match-all)
120993353 packets, 25892456892 bytes
Match: ip rtp 16384 16383
QoS Set
dscp ef
Packets marked 120993353
17643523 packets, 1143406405 bytes
Match: any
QoS Set
dscp default
Packets marked 1764352
