Last Disconnect Text is "destination out of order (27)"
Jan 30th, 2009
This voip peer is not working..
dial-peer voice 7204 voip
tone ringback alert-no-PI
description PTLS_ATL
destination-pattern 7204....
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
session target ipv4:10.60.200.25
What would cause that disconnect text?
paolo bevilacqua Fri, 01/30/2009 - 12:25
  • Hall of Fame,
    Founding Member
take a trace on 10.60.200.25 to find out.
Anonymous (not verified) Fri, 01/30/2009 - 12:32
Jaime Valencia Fri, 01/30/2009 - 14:04
  • Cisco Employee,
  • Hall of Fame,
    2011
Destination is out of order. The number dialed is a working number, but the span is not active.
at least that's for a PSTN call
when coming from VOiP it's almost the same as disconnect cause 3
No route to the destination. The dialed number is in the routing plan, but there is no physical route to the destination. The most likely cause of this is that the PRI D-channel is down, or the span or WAN is not connected correctly.
I've seen this when having 2 servers one froze and got unresponsive and there is no a higher higher preference dial peer to other server
java
if this helps, please rate
Anonymous (not verified) Sat, 01/31/2009 - 20:12
