LMS 3.1 RME 4.2 Archive failure
fashour
Archiving fails for all devices on RME. Checking the Reports it shows that it fails due to telnet failure. In my transport protocols I have telent as first method and tftp as second. credentials are confirmed to be correct as well as the snmp settings. Am I missing something?
Thank you
Joe Clarke
What is the exact error you're seeing in the job results?
Here you go
Device Name Config
Type File Type Accessed at Description
1. 10.141.10.252 PRIMARY RUNNING Sep 29
2008
10:32:38
TELNET: Failed to establish TELNET connection to 10.141.10.252 - Cause:
Authentication failed on device 3 times.
2. 10.141.101.254 PRIMARY STARTUP Jan 27 2009
18:41:43
TELNET: Failed to establish TELNET connection to 10.141.101.254 - Cause:
3. 10.141.101.254 PRIMARY RUNNING Jan 27 2009
18:41:53
4. 10.141.101.254 VLAN RUNNING Jan 27 2009
18:42:03
These errors point to bad credentials in DCR for these devices.  Export the DCR credentials for these devices from Common Services > Device and Credentials > Device Management, then confirm that you can login to these devices from the LMS server using those credentials.
