01-30-2009 12:35 PM - edited 03-06-2019 03:46 AM
Strange behaviour.
I have a cat2900xl and a 2950.
Just set VTP on both.
Interface are trunked in 802.1q on both (explicitly set on 2900xl, since by default it uses ISL).
Native VLAN is 1 on both.
Create VLANs on 2950 (which happens to be the VTP server), and they're connectly seen on the 2900xl.
Set VTP version 2, and both run in v2-mode.
Set pruning, and both set pruning.
create vlan4, and it's showed on both.
set an access port on vlan 4 on both, and traffic is not forwarded.
("show vlan" on 2900xl correctly shows the interface associated to vlan4).
notably, vlan4 is pruned on 2950 uplink interface (show interface trunk).
any hint?
TIA
Ivan
01-30-2009 02:14 PM
can you post your config with "show interface trunk", "show vlan" and "show spanning-tree vlan 4 summ".
02-02-2009 10:24 AM
02-02-2009 11:12 AM
Hi Ivan,
Can you make sure all related ports are in up/up state and capture "show spanning-tree vlan 4 detail" on both switches and "show interface trunk" on 2950?
Please post the related configuration as well, such as VTP config and port/trunk config.
02-02-2009 11:28 AM
I cannot run right now, since, due to service delivery, I have to move all devices currently running in vlan 4 into 2950.
Gonna wait till tomorrow, so I can find a suitable remote machines (it's a couple of miles away from here) connected to 2900xl, so I can move it to vlan 4, just to see what's changing, and give you the relevant show's output.
02-02-2009 11:21 AM
VTP prunning eleminate unneccessary broadcast requests from a Switch.
You have VTP configured, what is the VTP mode on both Switches? pls post sh int trunk from both?
Mohamed
02-02-2009 11:23 AM
show int trunk does not work on c2900xl.
For the output, see the attachment above
02-02-2009 04:51 PM
"sh interface status" will work.
02-07-2009 09:45 AM
you're right.
r-mi-ds69#sh int status
Port Name Status Vlan Duplex Speed Type
Fa0/22 r-mi-ds70 f0/1 connected trunk A-Full A-100 100BaseTX/FX
02-02-2009 11:23 AM
VTP is server on 2950 and client on 2900xl
02-02-2009 12:00 PM
another info:
2950 is running rapid-pvst+, meanwhile 2900xl is running vanillca pvst.
This never gave a problem, since usually the rapid downscales the port to shared
(right now trunk port is seen as "P2p Peer(STP)")
02-02-2009 04:27 PM
Can you post the trunk setup info for the 2900xl on the connecting port? If you can't ping between them then the trunk isn't working right.
02-02-2009 04:53 PM
Can you post the config for both the 2900XL and 2950 trunk ports?
02-07-2009 09:43 AM
sorry for the delay.
here they are.
cat2900xl#sh run int f0/22
Building configuration...
Current configuration:
interface FastEthernet0/22
description cat2950 f0/1
switchport mode trunk
end
cat2950#sh run int f0/1
Current configuration : 85 bytes
interface FastEthernet0/1
description cat2900xl f0/22
end
02-08-2009 01:39 PM
What VLAN IP Address on the switches are you trying to ping? Is this enabled? (Note: You can only enable ONE VLAN in the 2900/3500XL and 2950).
On the 2950, can you type and post the following commands:
sh int f0/1 status
sh int trunk
sh int f0/1 switchport
On the 2900, can you type and post the following commands:
sh int f0/22 status
sh int f0/22 capab
