redistributing the routes to MBGP
Jan 30th, 2009
Dears ,
<br />
<br />I'm planning to take MPLS VPN with two ISP's . The design is as atteched.Is there is any better option avilable for me ? . I have an internet connection on HO and on the same router I'm terminating 3 GRE Tunnels. What's the suggested method of redistributing the GRE routes to MPLS BGP session. Whether I can run BGP from internet router and mpls router ?
I need your suggetions before implementing the same .
<br />
<br />Regards
<br />
<br />
<br />1) hhhh.jpg
<br />
Laurent Aubert Sat, 01/31/2009 - 11:55
If the number of sites is not going to change I would go with static routes:
- 3x routes on your CE pointing to your PIX . Then your CE redistributes those routes into his BGP session with ISP1 and ISP2.
- 3x static routes on your 3845 pointing to the PIX.
- The PIX only need the same routes as the 3845 (but pointing t the CE)  as I suppose it already has a default route pointing to the 3845.
Of course you could also run an IGP between the CE, the PIX and the 3845 as well but I don't see the advantage of running BGP between the CE and the 3845.
Laurent.
Haris P Mon, 02/02/2009 - 01:14
Dear Laurent,
Thanks for the suggetion .
As in the diagram ,I have the GRE tunnels on my Internet Router and I also wanted to create a backup GRE tunnels to same branches on ISP PE router . In that case whether it will make sense to run BGP between CE and 3845(internet router )
Haris
Laurent Aubert Mon, 02/02/2009 - 07:19
Hi Haris,
If you run BGP between the 3845 and your CE, unless you have a tunnel between them, the PIX will need to be aware of the routes as well so you should go with an IGP supported by the PIX.
Laurent.
