CCNA Voice Lab - Suggestions?
Jan 30th, 2009
Hi There,
<br /><br />I'm starting to prepare a lab for my CCNA Voice and eventually CCVP and was trying to come up with a simple but full lab topology for this. I have been using GNS3 but with the limitations of not having CUE is not fulfilling the requirements.
<br /><br />My first thought is to have 2x2800 series routers with CME and CUE connected through T1 cards with a pri crossover cable with some FXO/FXS and ATA's.
<br /><br />Do anyone have any suggestions on this lab?
<br /><br />Thanks,
<br /><br /><br />Justin
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Fri, 01/30/2009 - 16:38
Hi, that is OK, but 2800's and related HW are expensive for lab use. You can pretty much build the same scenarios with 1760 and 2610XM, on which you can fit an AIM or NM CUE.
