Graphical representation of routing?
Jan 30th, 2009
<p>I'm putting together a simple animation using Powerpoint to show how data would be routed in a small network under various conditions including link failures.</p>
<p>Is there a software application that will simulate network performance and present in a graphical way like I'm trying to do with powerpoint?  Hopefully something cheap I can buy for personnal use.  </p>
<p>Any thoughts appreciated!</p>
<p>Thanks</p>
brandon.j.payne Fri, 01/30/2009 - 20:28
Packet Tracer is a pretty good simulator, but you cant incorporate it into Powerpoint.  You could build the network in Packet Tracer then take a screen shot or record your screen to simulate a packet being passed through a network then post the video in Powerpoint.
rkruz1234 Mon, 02/02/2009 - 08:13
Thanks for that. Ill check out Packet Tracer. Is there a forum to ask questions on how to use it?
