CISCO 3845 PoE Troubleshooting help
Jan 30th, 2009
<p>I have a 3845 with a WIC-D-9ESW-POE module.  I had a CISCO VoIP phone configured to fa 0/1/0 and it stopped working.  I currently have an amber light constantly lit on fa 0/1/p without anything connected and with or without the por being shutdown.  I have also tried my VoIP phone on other ports of this same router and it does not power up.  I have reset the router and powered it off and back on with no change.  I am suspecting the power daughter board to be defective but am wondering if there is a precise test method I can perform to verify this.  Can I check a voltage on the ethernet cable and if so what pin and what voltage should I have.  Also is there a command I can execute to try and reset the power problem.</p>
royalblues Sat, 01/31/2009 - 01:43
  • Green, 3000 points or more
Try Reseating the module again and if it doesnt help raise an RMA with Cisco
Narayan
