OSPF interArea: why advertise /32 prefixes?
Answered Question
Jan 31st, 2009
<p>Hi,<br />
I have 2 routers R2 and R3 in a point-to-point serial connection. OSPF is configured.<br />
R2 is getting interArea routes forwarded by R3. I still don't know why R2 gets /32 prefixes these routes.<br />
<br />
example on R2:<br />
"     192.168.9.0/32 is subnetted, 1 subnets<br />
O IA    192.168.9.1 [110/65] via 172.16.23.3, 00:01:09, Serial0/1 "<br />
<br />
although the subnets are configured with /24 prefix. <br />
Any ideas? and how to advertise the correct subnet mask?</p>
Correct Answer by Giuseppe Larosa about 7 years 12 months ago
Hello Wassim,
if the ip subnet is associated to a loopback interface to have OSPF to advertise the right mask you need:
int loop M
ip ospf network point-to-point
otherwise OSPF will advertise a /32 for a loopback ip address
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Sat, 01/31/2009 - 02:29
Hello Wassim,
int loop M
Hope to help
Giuseppe
royalblues Sat, 01/31/2009 - 02:34
I assume 192.168.9.1 is a loopback interface on R3
OSPF by default will advertise the loopbacks as a /32 subnet. Inorder to advertise it as a /24 you need to define the interface as point-to-point
interface loop 1
ip add 192.168.9.1 255.255.255.0
Narayan
