01-31-2009 03:52 AM - edited 03-15-2019 03:53 PM
<p>Hi,</p>
<p> </p>
<p>Running UCM 6.1.2 custer.</p>
<p> </p>
<p>Having 3 locations.Two locations are having local Callmanager group and other location having SRST. There are two Media Resource Groups are configured.</p>
<p> </p>
<p>SRST location and one loaction are sharing same Media Resource group with different Device Pool. In SRST location MeetMe and Ad-Hoc conference working fine but other location it's not working(the Media Resource are local for this location).</p>
<p> </p>
<p>If i select second Media Resource Group for this location, MeetMe and Ad-Hoc conference works fine.</p>
<p> </p>
<p>Please help me out!!!</p>
<p> </p>
<p>Regards,</p>
<p> </p>
<p> </p>
01-31-2009 10:03 AM
In the location where things aren't working....what's there? A CCM server? A Router?
Are you using software or hardware resources for conferencing....and where are these installed?
01-31-2009 04:39 PM
check the codecs being used, SW CFB can only handle G711
Java
If this helps, please rate
02-02-2009 06:06 AM
Using only Software conferencing bridge.
First location Publisher & 1 subscriber installed, second location 1 suscriber installed and third location SRST routers installed.
Media Resource Group is comman for Location 1 & 3. But in location 1 where the CCM are installed Conferencing is not working,but selecting other Media resource group (created for location2),conferencing will work fine.
Between the regions using G729 codec.
02-02-2009 06:10 AM
DO you have transcode resources configured? The software based conference bridge will not support anything but G.711. If you're running resources that are having to connect between locations via G.729 based on locations/regions settings, it won't work without transcode resources in place, and those are only done in hardware.
02-02-2009 06:13 AM
With SW conference bridge, you need to makesure that the region your CFB is in and the location is using G.711 beaciuse this is the only codec that is supported
