VRRP with Multiple VLANS
bspear123
<p>Can someone provide me an example config for running VRRP with multiple VLANS on a router?  Does multicast have to be enabled ?  I cannot get more than one VRRP group to failover on a VLAN.  Here is the config i have so far:</p>
<p>track 2 interface Serial0/0 line-protocol<br />
!<br />
!<br />
!<br />
!<br />
interface FastEthernet0/0<br />
 no ip address<br />
 ip pim dense-mode<br />
 duplex auto<br />
 speed auto<br />
!<br />
interface FastEthernet0/0.7<br />
 encapsulation dot1Q 7<br />
 ip address 10.251.101.2 255.255.255.0<br />
 vrrp 2 ip 10.251.101.1<br />
 vrrp 2 priority 110<br />
 vrrp 2 track 2 decrement 60<br />
!<br />
interface FastEthernet0/0.100<br />
 encapsulation dot1Q 100 <br />
 ip address 10.251.217.130 255.255.255.192<br />
 vrrp 1 ip 10.251.217.129<br />
 vrrp 1 priority 110<br />
 vrrp 1 track 2 decrement 60</p>
Yudong Wu
Level 7
Level 7
Not sure if I understand your question correctly. I don't think you need enable multicast. VRRP peer routers just need a pure layer two connectivity. Can you check your switch configuration to make sure both vlan 7 and 100 are trunked and permitted between two VRRP peers. Is the status of VRRP on both vlan 7 and 100 correct (one active and one standby)?
