Unlock code for Cisco 7975
Answered Question
Jan 31st, 2009
  • Silver, 250 points or more
  • Community Spotlight Award,
    Best Publication, November 2015
<p>What's the unlock code for a Cisco 7975?  I've tried **##**, but that doesn't work. </p>
Correct Answer by paolo bevilacqua about 8 years 3 months ago
Hmm isn't **# to unlock and two more * to reset ?
I always forget how it is but when on the phone can do it :)
Overall Rating: 5 (1 ratings)
paolo bevilacqua Sat, 01/31/2009 - 10:12
  • Hall of Fame,
    Founding Member
Hi, the code can have been blocked by the admin, and there isn't another one.
Or it is a phone not under corporate CM?
Clifford McGlamry Sat, 01/31/2009 - 10:38
Phone is on Corporate CM.
How would admin block this?  I see a spot where you can put a local phone password in the common device profile, but this is blank.  I tried changing it, but it doesn't seem to have any effect (maybe CCM service restart required???)
paolo bevilacqua Sat, 01/31/2009 - 10:41
  • Hall of Fame,
    Founding Member
You are right, admin can password protect settings but that doesn't appear your case. Try the correct sequence **# again ?
Rob Huffman Sat, 01/31/2009 - 10:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Clifford,
Have you tried pressing the "Settings" button and then pressing **#** (note only 1 #)
Hope this helps!
Rob
Correct Answer
paolo bevilacqua Sat, 01/31/2009 - 10:32
  • Hall of Fame,
    Founding Member
Clifford McGlamry Sat, 01/31/2009 - 10:40
That was it.
**# unlocks it.  **#** resets.
On earlier models **##** was the unlock, and **#** was reset.
Thanks for the help
paolo bevilacqua Sat, 01/31/2009 - 10:43
  • Hall of Fame,
    Founding Member
Ah. didn't know of the older sequences. In fact they make more sense as do not overlap.
Thanks for the nice rating and good luck!
