PVDM2-32 DSP Firmware ERROR!!!
Jan 31st, 2009
<p>I have a 2811 ISR and put in a PVDM2-32 and configured the PRI and everything was good until I tried to make some calls.  I did some show voice dsp commands and I'm getting this error, can anyone point me in the right direction:</p>
<p>sh  voice dsp group all<br />
DSP groups on slot 0:<br />
dsp 1:<br />
  State: FAIL, firmware: 0.0.0<br />
  Max signal/voice channel: 16/16<br />
  Max credits: 240<br />
  num_of_sig_chnls_allocated: 16<br />
  Transcoding channels allocated: 0<br />
  Group: FLEX_GROUP_VOICE, complexity: FLEX<br />
    Shared credits: 240, reserved credits: 0<br />
    Signaling channels allocated: 16<br />
    Voice channels allocated: 0<br />
    Credits used: 0</p>
<p>dsp 2:<br />
  num_of_sig_chnls_allocated: 9<br />
    Signaling channels allocated: 9<br />
    Credits used: 0</p>
<p>  0 DSP resource allocation failure</p>
<p><br />
 sh  voice dsp voice</p>
<p>DSP  DSP                DSPWARE CURR  BOOT                         PAK     TX/RX</p>
<p>TYPE NUM CH CODEC       VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK CO<br />
UNT<br />
==== === == ======== ========== ===== ======= === == ========= == ===== ========<br />
====<br />
edsp 0001 01 g729r8 p  0.1 IDLE  50/0/1.1<br />
edsp 0002 01 g729r8 p  0.1 IDLE  50/0/2.1<br />
edsp 0003 01 g729r8 p  0.1 IDLE  50/0/3.1<br />
edsp 0004 01 g729r8 p  0.1 IDLE  50/0/4.1</p>
<p>Warning! DSPs1, 2,  in slot 0 are using non-default firmware from flash:<br />
This is not recommended, the default version is 23.8.0</p>
<p>----------------------------FLEX VOICE CARD 0 ------------------------------<br />
                           *DSP VOICE CHANNELS*</p>
<p>CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending<br />
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending</p>
<p>TYPE  NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK CO<br />
UNT<br />
===== === == ========= ========== ===== ======= === == ========= == ==== =======<br />
=====<br />
C5510 001 01 None           0.0.0 bad   idle      0  0                 0<br />
  0/0<br />
C5510 001 02 None           0.0.0 bad   idle      0  0                 0<br />
  0/0</p>
<p> </p>
Overall Rating: 5 (1 ratings)
paolo bevilacqua Sat, 01/31/2009 - 11:11
  • Hall of Fame,
    Founding Member
Hi, it after reseating the module (try a different slot) still problems, the PVDM2 is for RMA.
Nicholas Matthews Sat, 01/31/2009 - 12:15
  • Red, 2250 points or more
If you're on 12.4 code, this would be a hardware problem.  I believe we had some instances of things like this in 12.2-12.3 code with some software bugs.
Generally same as Paolo said - reseat the cards, and otherwise RMA the PVDM2-32.
-nick
