Jan 31st, 2009
<p>I have an 1841 with two internet circuits and I'm wanting to configure the circuits for failover.  Is there a way to have the router ping ISP1s default-gateway and if it fails use ISP2s gateway?  Please note that it is imperative I track an IP address rather then the state of the WAN interfaces.</p>
<p>Thanks in advance!</p>
Richard Burts Sun, 02/01/2009 - 14:28
The link provided by Greg is pretty good and should show you what you need to do. I set up something pretty similar to what you describe. I did it on 2800 rather than 1800 but it should work well for you on your 1841.
