Exec-Callback with aaa new-model
Jan 31st, 2009
<p>Hi Friends,</p>
<p>I am using exec-callback on my aux port of a Cisco 2821 for out-of-band access to the router in case of network outages. It all works perfectly when I call the router and login with my dialback account, the link drops and the router calls me back..</p>
<p>Issue is I need to run AAA so when I use the "aaa new-model" and aaa commands (which also work fine) I don't run into problems until I try the exec-callback... When I dial the modem and connect on the AUX port, I get the username prompt but the issue is, it doesn't hang up and call me back.</p>
<p>Anyone have see and fixed this before... I'm sure there are some aaa authencation/authorization commands which need to be defined but if someone has figured this out... Please share the solution.</p>
<p>Thanks, Chris.  </p>
