Fax Configuration Sample
Jan 31st, 2009
<p>HI all hope you doing well,</p>
<p> </p>
<p>SO i hav a Fax machine attached to my Cisco Router using an FXS port and my Fax line is via the FXO line</p>
<p>i have done the following configuration but it seems not working :</p>
<p>Convention ===> Port FXS 0/0/0<br />
                      ===> Port FXO 1/1/1  <br />
<br />
dial-peer voice 1 pots<br />
destination-pattern 9.T<br />
fax rate voice</p>
<p>port 1/1/1<br />
<br />
destination-pattern 1234 <== Le numéros de ton fax<br />
port 0/0/0</p>
<p>Can anyone plz post a sample configuration !!</p>
<p> </p>
<p>Thanks in advance</p>
Paolo Bevilacqua Sat, 01/31/2009 - 13:21
Hi, no additional configuration is needed. In fact, you don't even need "fax rate voice".
Nicholas Matthews Sat, 01/31/2009 - 13:25
If you're doing simple pots-to-pots you should have much of a problem.  Take fax rate voice off, as it's unnecessary for your configuration.  Othen that, this could be a working configuration.
Make sure your voice card doesn't have 'no local-bypass' under voice-card 0.  (local bypass is on by default).
From here you probably just have a simple dial peer problem.  Do a 'debug voip ccapi inout' and see what the incoming called number is for incoming faxes, and change your destination pattern.  For outgoing calls, use a plain analog phone and determine exactly which digits you need to use (with or without a 1, any access codes, 7/10 digit dialing, etc).
What exactly is the problem you have?
Seifeddine-Tlili Sat, 01/31/2009 - 14:03
Hi Nick thanks for your reply, he porblem is that even without the fax rate voice DISABLED it doesn't work i can receive a Fax call.
Nicholas Matthews Sat, 01/31/2009 - 14:44
If you plug an analog phone into the port instead of a fax machine does it ring?  This probably not a problem specific to faxing.
