Error writing config
Answered Question
Jan 31st, 2009
<p>This 3560 just started doing this to me, when I make a change and I issue wither "wr" or "wr m":</p>
<p>Building configuration...
<br />
 <br />
Error writing new config file "flash:/config.text.new"
<br />
Error writing new config file "flash:/private-config.text.new"[OK]</p>
<p>Verison:  Version 12.2(25)SEB4</p>
<p>Dir of Flash:</p>
<p>Directory of flash:/
<br />
 <br />
    2  -rwx         916  Oct 15 2008 15:25:02 -04:00  vlan.dat
<br />
    3  -rwx        1536  Jan 31 2009 16:42:31 -05:00  config.text.new
<br />
    4  -rwx       10668   Dec 1 2008 10:19:28 -05:00  config.text
<br />
    5  drwx         192  Feb 28 1993 19:05:20 -05:00  c3560-ipbase-mz.122-25.SEB
<br />
<br />
  359  -rwx     7173120   Jan 8 2009 09:44:54 -05:00  tftp
<br />
  360  -rwx     1797632   Jan 8 2009 09:51:28 -05:00  ftp
<br />
 <br />
15998976 bytes total (512 bytes free)</p>
<p>Not sure what the tftp and ftp is all about, I need to log back in and look at other 3560s and see if that is normal.  I was actually trying to prune a VLAN when this happened, so I will start a new thread with THAT issue!</p>
<p>Thanks!</p>
<p> </p>
<p> </p>
Correct Answer by glen.grant about 8 years 3 months ago
  Its trying to write the config file to flash   but you have no space left in flash to write anything .     Somebody tried to save to a tftp and ftp server but instead ended up  writing it to flash  for some reason .  You should be able to get rid of those  and free up about 9 meg worth of flash.
Overall Rating: 5 (1 ratings)
Correct Answer
glen.grant Sat, 01/31/2009 - 15:35
  • Purple, 4500 points or more
