FXO not answering PLAR
Feb 1st, 2009
<p>I have a 2621XM running 12.4(23) and CME.  I have a NM-HD-2V in slot 1 with a VIC2-2FXO card installed.  I have added the router to the CCM 4 as an H.323 GW.  I have my FXO port connected to my Vonage router.  I am able to make outbound calls from my home 7960 phones, out via the CCM to the H.323 GW, out the FXO port to the Vonage router, to the POTS and can ring my cell phone.</p>
<p>If I make the reverse call, I hear ring tone in my cell phone, but no indication that the FXO ever picks up the call.  I eventually get my Vonage voicemail.</p>
<p>Relevant config is included below:</p>
<p>!<br />
!<br />
voice-port 1/0/0<br />
 connection plar opx 1004<br />
!<br />
voice-port 1/0/1<br />
!<br />
!<br />
!<br />
!<br />
!<br />
dial-peer voice 1 pots<br />
 description 7 digit dialing to local El Paso<br />
 destination-pattern .......<br />
 port 1/0/0<br />
 forward-digits all<br />
!<br />
dial-peer voice 2 pots<br />
 description 10 digit dialing for long distance dialing<br />
 destination-pattern 1..........<br />
 port 1/0/0<br />
!<br />
dial-peer voice 3 pots<br />
 description 911 dialing<br />
 destination-pattern 911<br />
 port 1/0/0<br />
!<br />
dial-peer voice 10 voip<br />
 destination-pattern ....<br />
 progress_ind setup enable 3<br />
 progress_ind progress enable 8<br />
 session target ipv4:192.168.1.244<br />
 dtmf-relay h245-alphanumeric<br />
 codec g711ulaw<br />
 no vad<br />
!<br />
!<br />
!<br />
!<br />
gatekeeper<br />
 shutdown<br />
!<br />
!<br />
telephony-service<br />
 max-ephones 10<br />
 max-dn 20<br />
 ip source-address 192.168.1.1 port 2000<br />
 auto assign 1 to 10<br />
 system message Girard Phone System<br />
 create cnf-files version-stamp Jan 01 2002 00:00:00<br />
 dialplan-pattern 1 1... extension-length 4<br />
 max-conferences 4 gain -6<br />
 transfer-system full-consult<br />
!<br />
!</p>
<p>I also tried changing the dest pattern in dial-peer 10 to 1004 with no changes</p>
<p>Jeff</p>
Chris Deren Sun, 02/01/2009 - 07:50
Can you post "debug voice dialpeer", you have overlapping destination-patterns on your dial-peers, it's possible it's matching the wrong one.
HTH,
Chris
jeffrey.girard Sun, 02/01/2009 - 13:02
I removed all of the dial peers except for the inbound voip dial peer (I deleted dial peers 1, 2, and 3.  Still the same.  Debug voice dialpeer is below capturing an inbound call from my cell phone
May 26 23:43:07.983: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x859789EC,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
May 26 23:43:07.987: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
May 26 23:43:07.999: //-1/2A5835208053/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1004, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1004
   Result=Success(0) after DP_MATCH_DEST
May 26 23:43:08.003: //-1/2A5835208053/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20004
     2: Dial-peer Tag=10
May 26 23:43:19.975: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
May 26 23:43:19.987: //-1/317D6E108056/DPM/dpMatchPeersCore:
May 26 23:43:19.991: //-1/317D6E108056/DPM/dpMatchPeersCore:
May 26 23:43:19.991: //-1/317D6E108056/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
Chris Deren Sun, 02/01/2009 - 18:01
So, is your phone with DN 1004 registered to CallManager or CallManager Express? The debug indicates that you have ephone-dn with DN 1004 configured, is that ephone registered at this time or is it registered to CallManager?
Also, I am confused as to why you are running CME if you have CallManager? Can you explain your strategy?
HTH,
Chris
