LMS 2.6 - MAP Topology
Feb 1st, 2009
<p>Hi Experts,</p>
<p>Quick Question</p>
<p>1.) Can I export the map to the Network Topology?</p>
<p> 2.) If yes, I need to view only the network Devices on that particular Map, City for example.</p>
<p>3.) Can I used Google Earth Map?</p>
Joe Clarke Sun, 02/01/2009 - 08:52
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
1. The topology map can be exported to Visio.  This is found under the File menu.
2. You can create a custom topology group, then export only the devices on that group.
3. I don't understand how you want to use Google Earth.  My guess is no, though.
