CUCM version in two different part
Feb 1st, 2009
<p>Hi All,</p>
<p>I have downloaded CUCM software version in two different part, can any one help me getting the procedure to combain both the part,</p>
<p>Regards</p>
<p>Abdul...</p>
Rob Huffman Sun, 02/01/2009 - 03:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Abdul,
Here is an example;
Upgrading From Cisco Unified Communications Manager Release 6.1(1x) or higher to Release 6.1(3) by Using the UCSInstall File
Because of its size, the UCSInstall iso file, UCOS_6.1.3.1000-16.sgn.iso, comprises two parts:
•UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part1of2
•UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part2of2
Procedure
Step 1From http://www.cisco.com,')">www.cisco.com, download the two UCSInstall files.
Step 2Execute one of the following commands to reunite the two parts of the file.
NoteThe 6.1.3.1000-16 build represents a non-bootable ISO that is only useful for upgrades. You cannot use it for new installations.
a.If you have a Unix/Linux system, cut and paste the following command from this document into the CLI to combine the two parts:
cat UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part1of2 UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part2of2 > UCSInstall_UCOS_6.1.3.1000-16.sgn.iso
b.If you have a Windows system, cut and paste the following command from this document into the command prompt (cmd.exe) to combine the two parts:
COPY /B UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part1of2+UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part2of2 UCSInstall_UCOS_6.1.3.1000-16.sgn.iso
Step 3Use an md5sum utility to verify that the MD5 sum of the final file is correct.
417c262e5706103c4e75a825e1d5d902 UCSInstall_UCOS_6.1.3.1000-16.sgn.iso
From these Release Notes;
http://www.cisco.com/web/software/282074295/24094/ciscocm-6-1-3.Readme.pdf')">http://www.cisco.com/web/software/282074295/24094/ciscocm-6-1-3.Readme.pdf
Hope this helps!
Rob
