Mobility Advantage
Feb 1st, 2009
<p><strong>Hi Team,</strong></p>
<p>I need some really good inputs regarding the CUMA configuration. I am using the version 3.1.2.</p>
<p>Installation was fine. After that I logged in and succesfully did the First step. SSL certificate uploaded.</p>
<p>Then we come to Enterprise Config, I am stucked up in that.</p>
<p>When it comes to ""Corporate Directory Configuration - Active Directory""", I am really confused with the Base DN syntax. In the doc it says ""DC=department,DC=example,DC=com"", I tried that....But no success...Please guide me for the configuration.</p>
Tommer Catlin Mon, 02/02/2009 - 08:40
  • Green, 3000 points or more
well, you need to talk to your Active Directory person. They will give you the correct context to us.
For example"
What you have listed is:
Example.com (active directory)
OU= Department
(all users in this OU will be listed)
You need to take a look at your AD and see what the LDAP context is to us. Every AD is different.
