2950 IOS upgrade via FTP problems
Feb 1st, 2009
<p>I seem to have issues upgrading the 2950 IOS via FTP - it usually just hangs and then I cannot access it for a while. I've tried copying the .bin or also tried the tar via the archive command - I've tried this via 2 FTP servers to rule out the server. I've also tried this on other switches like a 3560 which works great using the same FTP server on the same network as the 2950. Any ideas?</p>
glen.grant Sun, 02/01/2009 - 10:19
    I would check the space in flash usually the 2950 has room for 1 image and you have to delete that image to put a new one on .
