Problem with Incoming ISDN BRI connection. Cisco doesn't hang off.
pavelsh_ucs
<p>Cisco calls to out very well.</p>
<p>But incoming connections were failed. Cisco doesn't send CALL_PROC. :(</p>
<p>debug isdn q931</p>
<p>*Feb  1 19:56:19.013: %LINK-3-UPDOWN: Interface BRI0/1/0, changed state to up<br />
*Feb  1 19:56:19.065: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8  callref = 0x64 <br />
        Sending Complete <br />
        Bearer Capability i = 0x8090A3 <br />
                Standard = CCITT <br />
                Transfer Capability = Speech  <br />
                Transfer Mode = Circuit <br />
                Transfer Rate = 64 kbit/s <br />
        Channel ID i = 0x89 <br />
                Exclusive, B1 <br />
        Calling Party Number i = 0x0183, '00498945080860' <br />
                Plan:ISDN, Type:Unknown <br />
        Called Party Number i = 0xC1, '6722011' <br />
                Plan:ISDN, Type:Subscriber(local)<br />
*Feb  1 19:56:19.069: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0/1/0, TEI 112 changed to up<br />
*Feb  1 19:56:33.993: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0/1/0, TEI 112 changed to down<br />
*Feb  1 19:56:33.993: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2<br />
*Feb  1 19:56:50.845: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0x64 <br />
        Cause i = 0x8090 - Normal call clearing<br />
*Feb  1 19:56:50.853: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0x64 <br />
        Cause i = 0x8090 - Normal call clearing</p>
Ok. Reload the box ?
11 Replies 11
paolo bevilacqua
Config? Have you configured isdn answer for example ?
interface BRI0/1/0
 no ip address
 isdn switch-type basic-net3
 isdn incoming-voice voice
 trunk-group ISDN
voice translation-rule 3
 rule 1 /^6722011$/ /41111/
voice translation-rule 4
 rule 1 /^\(.+\)/ /0\1/ type subscriber subscriber plan isdn isdn
 rule 2 /^\(.+\)/ /00\1/ type national national plan isdn isdn
 rule 3 /^\(.+\)/ /000\1/ type international international plan isdn isdn
voice translation-profile IN
 translate calling 4
 translate called 3
voice-port 0/1/0
 disc_pi_off
 no vad
 compand-type a-law
 cptone CH
dial-peer voice 203 voip
 description ToCCM-Swiss
 huntstop
 destination-pattern 411..
 progress_ind setup enable 3
 modem passthrough nse codec g711ulaw
 voice-class codec 1
 voice-class h323 1
 session target ipv4:10.255.252.5
 dtmf-relay h245-alphanumeric
 fax rate disable
 no vad
dial-peer voice 101 pots
 trunkgroup ISDN
 tone ringback alert-no-PI
 translation-profile incoming IN
 preference 1
 incoming called-number .T
 direct-inward-dial
 forward-digits all
Doesn't show a reason for that. Which IOS is that ? You can also try isdn tei-negotiation preserve under bri. Also check a debug cch323 if something is going on on that side.
(C2800NM-ADVIPSERVICESK9-M), Version 12.4(15)T5
*Feb  1 21:28:46.585: %LINK-3-UPDOWN: Interface BRI0/1/0, changed state to up
*Feb  1 21:28:46.637: ISDN BR0/1/0 Q921: User RX <- UI sapi=0 tei=127
*Feb  1 21:28:46.637: ISDN BR0/1/0 Q931: SETUP pd = 8  callref = 0x62
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
*Feb  1 21:28:46.689: ISDN BR0/1/0 Q921: User RX <- UAf sapi=0 tei=97
*Feb  1 21:28:46.693: ISDN BR0/1/0 Q921: User RX <- UAf sapi=0 tei=98
*Feb  1 21:28:46.729: ISDN BR0/1/0 Q921: User RX <- RR sapi=0 tei=97 nr=1
*Feb  1 21:28:46.741: ISDN BR0/1/0 Q921: User RX <- RR sapi=0 tei=98 nr=1
*Feb  1 21:28:56.745: ISDN BR0/1/0 Q921: User RX <- RRf sapi=0 tei=98 nr=1
*Feb  1 21:28:56.749: ISDN BR0/1/0 Q921: User RX <- RRf sapi=0 tei=97 nr=1
*Feb  1 21:29:06.761: ISDN BR0/1/0 Q921: User RX <- RRf sapi=0 tei=98 nr=1
*Feb  1 21:29:06.765: ISDN BR0/1/0 Q921: User RX <- RRp sapi=0 tei=97 nr=1
*Feb  1 21:29:06.769: ISDN BR0/1/0 Q921: User RX <- RRf sapi=0 tei=97 nr=1
*Feb  1 21:29:07.649: //-1/xxxxxxxxxxxx/H323/cch323_process_carrier_update: Registered = 0, Event = 1, Reason = 2
*Feb  1 21:29:16.777: ISDN BR0/1/0 Q921: User RX <- RRf sapi=0 tei=98 nr=1
*Feb  1 21:29:16.789: ISDN BR0/1/0 Q921: User RX <- RRf sapi=0 tei=97 nr=1
*Feb  1 21:29:24.553: ISDN BR0/1/0 Q921: User RX <- INFO sapi=0 tei=98, ns=0 nr=1
*Feb  1 21:29:24.553: ISDN BR0/1/0 Q931: RELEASE pd = 8  callref = 0x62
*Feb  1 21:29:24.561: ISDN BR0/1/0 Q921: User RX <- INFO sapi=0 tei=97, ns=0 nr=1
*Feb  1 21:29:24.561: ISDN BR0/1/0 Q931: RELEASE pd = 8  callref = 0x62
*Feb  1 21:29:24.597: ISDN BR0/1/0 Q921: User RX <- RR sapi=0 tei=98 nr=2
*Feb  1 21:29:24.617: ISDN BR0/1/0 Q921: User RX <- RR sapi=0 tei=97 nr=2
*Feb  1 21:29:30.585: ISDN BR0/1/0 Q921: User RX <- UAf sapi=0 tei=98
*Feb  1 21:29:30.589: ISDN BR0/1/0 Q921: User RX <- UAf sapi=0 tei=97
*Feb  1 21:29:32.649: //-1/xxxxxxxxxxxx/H323/cch323_process_carrier_update: Registered = 0, Event = 1, Reason = 2
May be stupid question but you have DSP in the box ?
Cannot really suggest a reason why that is happening.
Yes
CHIIRouter#sh voice dsp voice
----------------------------FLEX VOICE CARD 0 ------------------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
DSP   DSP              DSPWARE CURR  BOOT                         PAK   TX/RX
TYPE  NUM CH CODEC     VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 None           9.4.5 idle  idle      0  0                 0          0/0
C5510 001 02 None           9.4.5 idle  idle      0  0                 0          0/0
C5510 001 03 None           9.4.5 idle  idle      0  0                 0          0/0
C5510 001 04 None           9.4.5 idle  idle      0  0                 0          0/0
C5510 002 15 None           9.4.5 idle  idle      0  0                 0          0/0
C5510 002 16 None           9.4.5 idle  idle      0  0                 0          0/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
Any chance to try another release like 12.4(3) latest ?
I don't think I ever seen that happen.
This ios working very well on two another routers. I copy config from them.
After reload CALL_PROC are transmited, but I get new error. I try to solve new problem.
Reload is helping me.
Thank you very much
