DHCP for LAN and WLAN
Answered Question
Feb 1st, 2009
<p>My problem is to get an IP with the WLAN-Clients. They could connect but didn't become a dhcp-lease.</p>
<p>I've looked in all the other posts for dhcp, but couldnt locate my problem.</p>
<p>Any help is welcome. Config is attached.</p>
Correct Answer by Leo Laohoo about 8 years 3 weeks ago
So if the wireless clients get associated to the AP and they do not get a valid IP Address (range of 192.168.10.200 to 192.168.10.210), what IP Address(es) are they getting?
If they are not getting the default 169.x.x.x IP Address then there could be a DHCP server nearby? If the answer is yes (that they are getting a valid IP Address from a nearby DHCP Server), IP Helper Address?
Overall Rating: 3.5 (2 ratings)
Leo Laohoo Sun, 02/01/2009 - 22:11
So the clients get associated to the wireless AP but can't get ip addresses from 192.168.10.200 to 192.168.10.210?
Correct Answer
Leo Laohoo Mon, 02/02/2009 - 13:05
Carsten Radke Tue, 02/03/2009 - 05:02
The Client doesn't get an IP and the only dhcp server is on the router.
Could it be that i've to diable the ip inspect ?
Carsten
arthurbutt Wed, 02/04/2009 - 05:33
I am having the same issue with a new 1231 AP. It gets a windows (local) IP of 169.x.x.x.
jeff.kish Thu, 02/05/2009 - 06:38
Try adding the bridge-group 1 command to your Dot11Radio0.1 subinterface. I've seen this problem before and it generally relates to bridge-groups.
Carsten Radke Thu, 02/05/2009 - 08:37
Thats was the problem, thanks jeff.
I changed the config in:
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
broadcast-key vlan 1 change 45
ssid Carsten
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2462
station-role root
rts threshold 2312
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
and its working fine.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
