Can PIX/ASA disable stateful check?
Feb 1st, 2009
Hi, all
I have one ASA 5510 with software 7.0, configurated as transparent firewall. Now I want to disable its stateful check, Anyone can tell me whether it support this feature? If its a routed firewall,can it support, And what is the command?
Very Thanks
Tao
Overall Rating: 3 (1 ratings)
hetao1601 Mon, 02/02/2009 - 23:51
imartino
Very thanks for your reply.
1. From the explanation, it said nailed is used with 'failover timeout' command. What is that mean? I just want to disable the state check, so that asymmetric route traffic can pass through the pix. Can it support that?
BTW, I'd like to know whether it can be used on the transparent mode since it doesn't have the 'static' command.
2. It seem the following command is related with tcp state check.
invalid-ack {allow | drop}
Am I right?
Any reply is very appreciated!
Tao
