Vista not getting ip from cisco router
Feb 1st, 2009
Plz.any body can give solution to enable DHCP option which can release ip to Vista Machines.As some in Vista, DHCP Broadcast flag is set.
Expecting a solution to enable DHCP Offer as broadcast in cisco Router.
thanx.
Istvan_Rabai Sun, 02/01/2009 - 22:32
  • Gold, 750 points or more
Hi Vannam,
This is a simple example:
conf t
service dhcp
ip dhcp pool MYPOOL
network 192.168.1.0 /24
This example will distribute ip addresses from the pool specified by the "network" command.
Cheers:
Istvan
vannacisco Sun, 02/01/2009 - 22:49
Hi!
this is a basic configuration of DHCP!
Router releases ip to WIndows xp clients.
but the issue is with WIndows vista.
i search a method where i need to enable option in DHCP as "dhcp Broadcast flag" set.
As default vista eanble this settings n not getting ip from Cisco router.
tnx.
Istvan_Rabai Mon, 02/02/2009 - 10:12
Hi Vannam,
Sorry, you asked for a router configuration:
"Expecting a solution to enable DHCP Offer as broadcast in cisco Router. "
Cheers:
Istvan
Giuseppe Larosa Mon, 02/02/2009 - 11:27
  • Hall of Fame,
    Founding Member
Hello Vanna,
it looks like is an issue of Win Vista OS
see
kb928233 on microsoft site
there is a procedure to change a key with regedit
There was a thread about this some mounths ago. someone said is solved installing service pack on Vista PC.
I've given a look at command reference
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_dhc3.html#wp1011584
I couldn't find a command to do that
Hope to help
Giuseppe
vannacisco Mon, 02/02/2009 - 19:39
Hi !
there is a way where we can edit windows registry and then it gets ip form router.
but what is the solution cisco provide for this issue as it's something to do with DHCP Broadcast/Unicast compatiblility with vista.
Microsoft work vista having problem with non-micrsoft DHCP servers only.
whether we can get any support from CISCO regarding this.?
thanx
Giuseppe Larosa Mon, 02/02/2009 - 23:45
  • Hall of Fame,
    Founding Member
Hello Vanna,
they could have tested Vista in a multivendor environment...
the question is that RFCs contain suggestions, not everything is implemented and no other OS has used this option before.
http://support.microsoft.com/?scid=kb%3Ben-us%3B928233&x=11&y=10
Hope to help
Giuseppe
vannacisco Tue, 02/03/2009 - 00:05
Hi !
thanx for MS link to edit registry!
my question again is " whether cisco has any solution to this problem?" I mean any os update, and whether all cisco routers has the same issue with Vista clients?
is there any way we can ask Cisco to clarify on this issue!
thanx.
