Cisco Switch 3560 Temperature
Answered Question
Feb 1st, 2009
Dear All,
I have one of our switches showing Temp status as FAULTY, how you can help in this issue? Temp. About 127 C.
Please find attached pdf file.
Please help me in this regard.
Malik
Correct Answer by rtuttle about 8 years 3 months ago
sho env temp
or all
What does it say?
Correct Answer by glen.grant about 8 years 3 months ago
Where is the switch located , at that temperature it would be faulty or melted down . Check to see if the fans are running and whether the room where it is installed is adequately cooled.
Overall Rating: 5 (2 ratings)
Correct Answer
glen.grant Mon, 02/02/2009 - 08:23
  • Purple, 4500 points or more
tiger_401 Mon, 02/02/2009 - 12:56
Thanks for your reply. The switch is located in server room. All other devices are working fine.
Is there any command through which we can check the temo using CLI. Please do reply.
Thanks & Regards,
Malik
Correct Answer
rtuttle Mon, 02/02/2009 - 13:00
sho env temp
or all
What does it say?
tiger_401 Mon, 02/02/2009 - 13:24
I will check it and will let you know.
Malik.
chener.hamawandi Wed, 03/08/2017 - 06:23
SW01# sh env temperature
TEMPERATURE is OK
SW01# sh env temperature status
Temperature Value: 42 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 51 Degree Celsius
Red Threshold : 61 Degree Celsius
