Multicast over BT MPLS
gsidhu
Level 3
Level 3
Requirement is to multicast music on hold RTP stream from a Data Center to a remote site over BT IP Clear MPLS network. Catalyst 3750 switches (both running IP Services Image) will BGP peer with BT PE equipment. The Catalyst 3750 switches will also be configured with PIM-SM.
Does BT MPLS support IP Multicast? I could not find any info on the web so I am hoping people have tried it and (hopefully) it worked for them!
7 Replies 7
paolo bevilacqua
I think you will find that multicast is not supported on MPLS. Consequently, you will need to setup GRE tunnels to carry multicast. Since the 3750s are not apt for that, you will need dedicated routers.
Ayodeji Okanlawon
you can configure the remote site routers to stream MOH from flash because MPLS network will not support multicast.
I just did an install over BT IP Clear MPLS network and it was okay.
Here is a link to configuring this. You must follow every step of it. In some cases after you configure the gateway you may need to reload for it to work, I had to do this.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802d1c31.html
Below is a sample configuration I used.
NB Ensure the MOH file you use is in router's flash memory.
interface Loopback0
ip address 192.168.145.1 255.255.255.255
ip pim sparse-dense-mode
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.145.1
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.50
description Data VLAN 50
encapsulation dot1Q 50
ip address 10.144.50.254 255.255.0.0
interface FastEthernet0/0.144
description Voice VLAN 144
encapsulation dot1Q 144
ip address 192.168.144.1 255.255.255.0
ip helper-address 10.144.10.1
ccm-manager music-on-hold
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.144.50.254 port 2000
max-ephones 42
max-dn 144 dual-line
system message primary WAN Circuit Down
transfer-pattern .T
pickup 4625
call-forward pattern .T
moh SampleAudioSource.ulaw.wav
multicast moh 239.1.1.1 port 16384 route 192.168.145.1 192.168.144.1 10.144.50.
254
Please rate all useful posts
That seems a great recommendation, I've rated your post aokanlawon.
Paolo,
Thanks for the appreciation and as always you remain a model and inspiration here...
Thanks for the replies so far.
MoH is requred for external callers (over PRI ISDN circuits) as well as internal callers. My understanding that 'Non-Fallback Mode' will not provide MoH over POTs interfaces.
Looks like my options are limited.
If I deploy standalone MoH server, does this have to be on the same LAN as the UCM cluster or can it be on the remote site (RTT is less than 30 ms between the sites)?
This will work for external and internal callers in NON-Fallback Mode.
Please take a minute to read the documentation. This will work even if the router is not in SRST Mode, which is what you want
Thanks - I'll have a look through the documnentation. I'm glad it worked for you. I appreciate the configuration.
The SRND for 6.x mentions multicasting moh over 'local Cisco Communications devices' for Non-Fallback mode (no mention of POTS interfaces) and 'analog and digital ports within the chassis' for Fallback mode, which is why I queried this.
